Thank you to all those who offered suggestions on my problem with
epoxy viscosity. It appears that Riogrande has a low viscosity epoxy
adhesive that I’ll be trying.
Linda in central FL
where the mornings have finally reached the “lovely” stage!
Did you put the glue on the outer edge of the settings to keep the
glue from getting in the joint?"
I dipped the side of the tube setting in the glue, then placed it
with a tweezer, onto the dip I cut in the band. Then I soldered
the other band to the settings. Of course it didn't go as smoothly
as the photos depict. But the glue helped nonetheless.
Oooh. so you only glues the settings down on the one side to hold it
still to solder on the other. That makes sense!
