I’m trying to find white gold solder for 14K work with melting point
comparable to yellow gold’s and silver’s Extra Easy (or at least
Easy). The lowest I find is 1310Melt-1450Flow, which is like Ag
Hard. I’d like something that FLOWS at 1200 or at least 1300. I need
it for the final soldering on a complex piece with a lot of mirror
finish nickel white gold which is not accessable for polishing
afterwards, so I want to use as little heat as possible. Also don’t
want to use acetylene on it, as it has some easily meltable parts.
I think I have what you need. 14kt Extreme easy flow plumb solders.
Based on a Gallium/Indium patented alloy, the color is only fair. The
best color flows at a higher temperature.
Hi Daniel, I’ve always wondered where the term ‘plumb’ comes from in
’plumb solders’. Do you have a list of temps and properties for your
gold solders? Couldnt find it on the website. Is the color of the
14E Extreme veryb gray?
