Cameron,
I must say that I too tried metal clays thinking I could use the
stuff for “short cuts” in jewelry making, repair work, etc, as some
things seemed possible with clay, in theory, that were more
complicated with fine silver raw materials and would be easier with
24 kt gold clay as well…I learned - after investing a great deal in
abeehive type kiln, then onto a “PMC hotpot”, then firing cone, then
a secondary kiln dedicated to metal clay (I have one for annealing
and enameling), a generous supply of PMC then Art Clay then onto
making my own clay alloys, that it is not worth the outlay in the
long run. Better by far to stick to or learn traditional gold and
silver smithing and the processes that are intrinsic to the art.
Metal clay art looks like metal clay art, and with very few
exceptions that are breathtaking (Gordon Uyehara as a case in point)
the markets (in which I have seen sellers trying to sell metal clay
art) do not bear the costs of the final products. Equally, there
seems to be a stigma attached to metal clay products which dictates
that the perceived value is far less than traditional silversmithing.
The main point is after all the special equipment (other than firing
it on a gas stove- which by the way, works just fine) and investing
in a clay form of fine silver or high karat gold the cost is never
returned. I have found that for schools and other groups,
occupational therapy, camp projects, etc. in which safety is a
concern and all the equipment necessary for basic fabrication and
soldering is cost prohibitive metal clays can provide an
entertaining period and a tangible jewelery product for far less of
an investment…That said the most basic kiln with an attached
pyrometer or a supply of cones that indicate the kiln’s temperature
are more than adequate if you are testing the form.I would also
recommend seeking out a used kiln, with an attached pyrometer, and
preferably a front opening door, and inside tracks of which will
support additional tiles, or racks particularly if you are just
getting into metal clay as a possible jewelry making medium. I would
even say that unless you are absolutely certain that you are going to
continue working with metal clays for a very long time, if not
exclusively, the rapid fire cone is adequate unless you have a gas
stove and a stainless steel or cast iron domed cover to concentrate
heat is good enough for experimentation. The $800 (after you add on
shipping and taxes to the $650.00 kiln) or so you would spend on a
new kiln, if you are just beginning is far better spent on a torch
set up, raw materials and hand tools and learning to make jewelry on
your own! A butane torch and charcoal block are even quite adequate
and one will get the same results on say band rings, stone set rings,
or pendants etc. as you will investing in a form that, as a living,
is not as profitable as traditional methods, and In my opinion, no
where near as versatile nor predictable.
Even with the “new advances” and products available( like the
veneers that allow one to apply thin layers of texture, or mixed
metal inlays etc.) in the metal clay realm, your money would go much
farther investing in traditional equipment for fabrication.
The cost of metal clays is at least doubled ( though closer to
triple) the cost of .999 silver and gold raw materials ( sheet,
casting grain, wire, bezel, etc.).Then there are tiered lessons, and
privileges associated with buying into the tiered system of
instruction and being able to teach methods that allow one person to
get their clays cheaper than another that factors into the overall
high cost: low return: low perceived value. I truly urge you to
consider cost vs. return on investment before making that first
purchase of 7 grams of the stuff for $35.00 or so, when an entire
ounce of.999 silver is $17.31 (as of today) and your end product
will carry a far greater return- if selling your art is what you plan
for your work- not to mention that your results learning traditional
methods will be far more predictable!
After all metal clays are a great way to reuse industrial wastes and
for the manufacturers to profit from that recycling, but I expect the
fad to be quite short lived as many of the objects break easily, turn
black in contact with aluminum, are in general, obviously not
traditionally fabricated jewelry and consumers are beginning to
realize the shortcomings, and many former enthusiasts beginning to
realize that their investments will never be met with the same market
that exists for art jewelry.
Certainly many will disagree with my warnings to you, but many of
those who will protest will, no doubt be in the business of selling
metal clay accoutrement, teaching it, etc…so the objectivity I am
offering you as an individual that put out a great deal of money and
spent a lot of time to learn these things for myself, will be skewed.
If you are set on metal clays as a hobby, fine, just do it in the
most conservative way you can- Don’t opt for the fancy kilns with top
doors or separated compartments and dual controls- find a good used
kiln that can be resold if you tire of the results. If you are going
to open a school, or offer to teach metal clay on a storefront
premise, and/or charge per piece to fire patrons works, then buy the
better kiln that has clearly easily digitally controlled temperature
setting capabilities, and multiple compartments that allows one batch
to be fired while setting up a second in another cell in a unit
because it can be written off when you account for the outlay- after
the fad dies out.
rer
