Hello Everyone,
I have a question regarding soldering sterling silver.
I have just realized that my solder joins are not really “joining”.
(yikes) And I am not sure what I am doing wrong…
So, I began to practice soldering again. I did the below more than 30
times, with the same results
The set up: (I tried 2 different joins)
join #1-
15mm long, 2x1mm rect wire, on a charcoal block. 5mm long, 2x1mm
rect wire, laying across above wire. (kind of like a cross) secured
with a “staple” (made from small paperclip), also used pins…
join #2
20mm long, 2x1mm rect wire. mitered 5mm in from end, bent to a 90
degree “L” shape.
pieces sanded/filed flat, join is flush and clean. pieces fluxed
with grifflux #1. (I made a new batch of flux.) used one chip Rio
Hard sheet solder. (I used Rio med solder a few times as well).
used Smith Little Torch with #5 tip flame is approx 20-25mm long,
with a soft tipped blue cone. (I tried bigger and smaller flames as
well.)
I heat up the piece, watching for the flux to go clear and glassy.
then one of 2 things happens:
the flux goes clear, but the solder doesn’t flow, and the piece
starts going “bright orange” then the solder flows as the surface
of the metal goes “shiny”, so I pull the flame off. -
the flux goes clear, and the solder flows before the piece starts
going “bright orange”.
I pickle, then pull out the piece, and look at the join. I see a
solder “fillet” all around, so I think the join is good.
The problem:
Then, I take a pliers to check the join, and the 2 pieces pop
apart.
I then examine the 2 pieces, and on each piece I see a “broken
fillet” around where the 2 pieces touched, and where the pieces
touched there is a “fine, crusty, white residue” which sometimes has
some color in it (yellow, rust, brown, black). It appears that the
solder is not going “thru” the join".
The questions:
why is my solder not flowing thru the join? what is this crusty stuff
and why is it occurring? (is it flux?..)
I have not heard/read anything about this yet, and have been under
the impression that my joins were ok, so I never asked while in the
classes…
Any help would be greatly appreciated…I’m stuck in neutral.
Thank You,
Julie
