Can any of the Pripps gurus tell me where I’m going wrong? I made
some Pripps flux according to all the recipes and am frankly
struggling to have any success with it. My first problem is knowing
at what stage to spray on the flux. How long do you heat the piece
before spraying it on? Sometimes it works ok, but sometimes it just
goes on wet and it’s difficult to get coverage so you still end up
with the leopard spots and possible firestain. My second problem is
that when I use Pripps, I can’t get anything to solder. The solder
just won’t flow when the work is coated with Pripps. The third
problem is that I’m having to heat everything even hotter than usual
in an attempt to get the solder to flow. I had everything at red heat
for over ten minutes but nothing would melt. The snippets of solder
wouldn’t even melt enough to ball up! I repeatedly stopped, pickled,
rinsed, re-fluxed and tried again - all to no avail. Yes, it’s great
in that you get no firestain, but if you can’t even solder one piece
of metal to another, there’s not much point in it - heating up metal
for no purpose whatsoever. I must be doing something wrong.
So I’m back to using boric acid in alcohol and filing away
firestain. Any advice will be very much appreciated, thanks.
Helen Hill
UK
