What techniques do people use to prestretch their silk prior to
stringing. Currently, I am using the technique suggested by Rio
Grande on their stringing video (running the silk through the slots
on the card), but that tends to abrade the silk and doesn't seem to
be sufficiently stretching it. Any suggestions?
Hi JoAnna, Actually, I can offer you a couple of different
pre-stretching methods. These are leftovers from my bead
designing/stringing days in the early 80’s, and are relatively
interchangeable, as far as results are concerned… The first and
best (but most time-intensive) is to thread your silk through a
large nut (or around the base of the head of a carriage bolt), tie a
knot around it, and unwind about four feet of silk. Next, place your
silk spool in a vise or C-clamp, place it/weigh it in place atop a
bookcase, and clamp a large Vise-Grip plier onto the nut or bolt at
the other end. Last, spritz the thread with a water mister, then
leave this hanging in place until dry, or coax it along with a blow
dryer.
The other (and infinitely less labor intensive) version is to thread
about 6" of beads (any material other than Garnet, since it’s holes
tend to be more abrasive than most others) onto your doubled silk
thread, then hold the “needle” end of the thread (not just the
needle) in one hand, the other two ends in the other hand, and yank
the thread straight a few times. If you’re doing this properly, the
mass of beads will whip around and around, centrifugally, thus
stretching your thread! “Back in the day”, when I’d used this so
regularly, I’d pre-stretch each strand as just indicated, then
re-stretch the same strand every so often, to assure that no large
amount of elasticity remained. Finally, I’d do it one last time
after the entire strand was complete, just to be sure that all of
the knots would lie properly, and the strand would drape evenly.
Of the two methods, I’d recommend the second one for general usage,
and the first, for use with beads over about the 10mm mark,
considering that the potential for personal injury necessarily
grows, exponentially, when swinging larger weights around like that.
Hope this helps, JoAnna!
Best Regards,
Doug
Douglas Turet, GJ
Lapidary Artist, Designer & Goldsmith
Turet Design
P.O. Box 162
Arlington, MA 02476
Tel. (617) 325-5328
eFax (928) 222-0815
anotherbrightidea@hotmail.com
