Straightening thick wire is harder. I am also a lampworker (making
glass beads) so I found I roll the wire in my hand as I’m hammering
with a Delrin mallet. I just keep rotating the wire as I mallet away
and the wire comes out pretty straight. Not perfect but as straight
as I can. If it is really critical that your thick wires have to be
perfectly straight, then order it in 12" straight lengths. I have to
do that once in a blue moon.
Thanks for the suggestions. I have ordered 12" straightened pieces
from Hoover and Strong, but have been looking for a solution that
doesn’t generate so much waste as most of my work is in the 10" -
11" stock range. Thanks. Rob
A way that doesn’t require a drawbench is to hang the wire
vertically, attach a weight to the free end, and twist the wire a few
times. It works with thick wire as well as thin.
Gary. I hung a piece of 12 gauge wire that had been tightly coiled
securing it with a locking plier bigger than the hole in the weight.
I carefully snapped the weight down a couple times against the plier
and turned the the wire around a few turns and it was straight.
Thanks. Rob
