I use it for holding small difficult parts like earrings. You
can gently heat a piece so that it melts into the plexi surface a
bit or take two pieces of thicker plexi 3/32 or thicker and carve
a cavity to hold the item wioth just a slight gap between the
plexi pieces. Taping the back side to make a hinge is a
suggestion someone else made- now why didn’t I think of that?..
Rings I usually hold in a ring clamp, the die ball or the
Benchmate. A ring mandrel works well too- I’ve chased in some
stones and even used a small hammer directly on some stubborn
bezels.
I imagine that skip can suggest some materials from his dental
tech background that could be used to make reusable holders.
Rick
Richard D. Hamilton
wax carving, modelmaking, jewelry photography
