First of all it’s worth mentioning. dont overheat the stainless when
silversoldering… and you will have way less cleanup.
“Pickling” stainless can be accomplished using citric acid and
electrostripping method.
I use about a cup of citric in quart of water for the “pickle”
for the electro stripping power use a dewalt 18 volt battery (or
suitable power supply though that’s more of an electronic tech’s
arena)
Use a voltmeter to figure out which battery terminal is positive.
You must be sure.
Ask for help from a knowledgeable friend or go visit the local
vo-tech electronics class/ auto parts place/ if you are not ok with
this part.
Hook up:
the positve battery lead connects to the “work” to be stripped (via
a flexable copper wire and alligator clip, each end)
the negative battery lead - goes to a “handle” you must make from
someting insulating like small diameter pvc or plastics. smallish but
sturdy.
run the neg lead through said handle, to a small piece of an
abrasiveplastic material like a 3m plasticized scrubbe. You want it
to t hold the scrubber but NOT contact the “work”.
put the stainless in the “pickle”…with positive lead
attached… use the handled scrubber to softly abrade the oxides
while immersed in pickle. a little work and patience will work
wonders…
(you do not want the positive lead to directly contact the work,
sincethe negative lead is already connedted that would be a short
circuit)
stainless is cool on jewelry. but you will work for it. it polishes
up like chrome… bling bling on the cheap
I would like to thank the person who shared this with me, here on
Orchid. unfortunately i’ve forgotten his name.
steve
Everything should be made as simple as possible, and no simpler.
