If there's any such thing as pulmonary arrest as a reaction to
sulfuric acid, it's news to me.
If your comment means that breathing in acid vapors do not have
consequences, than you should take your own advice and check the
facts. Also consider that having any chemical liquid open will result
in evaporation and vapors will carry minute particles of the liquid (
acid in our case ) with them, so if you are in the room with the open
container containing the hot liquid, you are breathing it in.
The hotter the liquid, the more pronounced the effect. Pulmonary
arrest implies immediate reaction to a contact. That is not what I
wrote.
Prolonged contact with acid leads to neurological damage which can
lead to severe damage to lungs and pulmonary arrest as a consequence.
Beside if smoking is dangerous, what do you think pickle vapors doing
to your lungs?
Dilute sulfuric acid does not dissolve copper, period. Hot
concentrated acid does, but thatâs another story. If it did, you
would shortly not have a vessel, now would you?
What needs to be understood here is the action of boiling a
jewellery in a copper vessel containing dilute sulphuric acid is not
the same as conducting reaction between copper and dilute sulphuric
acid.
I will help you to understand this process.
First what must be realized is that text book reactions assume pure
components which do not exist in real world. Second is the
concentration of the solution is changes as boiling progresses.
With this in mind letâs examine what happens in the pot. The purpose
of pickling is not only to remove melted flux but also to remove
oxides. Working with gold alloys creates copper oxide since most of
practical gold alloys contain copper. Copper oxide react with dilute
sulphuric acid readily.
Cu2O + H2SO4 = Cu + CuSO4 + H2O
In words the result is copper, copper sulphate, and water. So the
process like this. We put jewellery in a copper pot, add dilute acid
and boil it under the hood. Flux is dissolved together with copper
oxides, pure copper is deposited on the bottom of the pot and copper
sulphate stays in solution.
Remaining acid stays a pot since since, like you stated, it does not
reacts with copper, but I would add to this practically, since there
is no such things as total inertness.
Immediately after boiling the concentration of the acid increases
due to water evaporation and some consumption of deposited copper
takes place, but since sulphuric acid is hydroscopic, the
concentration will fall in time. Eventually solution turns blue and
needs to be replaced.
but the danger of mixing and storing acid is far outweighed by that,
which is why the industry lives on Sparex.
Here is the link to sodium bisulfite MSDS
http://physchem.ox.ac.uk/MSDS/SO/sodium_bisulfite.html
Anybody who thinks that it is safer than sulphuric acid should read
it. Pickle based on sulphuric acid you keep cold and bring it to boil
only when needed, Sparex must be kept hot in a busy shop. It works
cold but takes too long. So even if we assume it is 100% effective,
which is not, the exposure to hot vapors throughout the day is far
more dangerous than having cold container of dilute sulphuric acid.
As
far as handling the acid, it is not that complicated.
I am sorry if this is blunt, but please check facts before
posting. Misabout chemistry is dangerous and quite
easily researched before hand. There is much chemical lore in our
trade, but it's quite simple to check the facts, if one is inclined
to.
I like blunt. I am not much into mincing the words myself, so it is
always good to remember that what appears as miscould be
our haste in judging the and failure to understand the
process for what it is.
Frankly, when I started in this business, one could not even find a
bench without a small copper pot hanging on the side of it, used for
pickling. Everybody used his own. My first exercise in working with
metal was making a scoop for filing and the second was making a
pickle
pot out of copper. So I am really surprised that you are not aware of
this procedure.
Leonid Surpin.
