Hello everyone,
I was wondering if anyone had run across a supplier that will supply
larger diameter sterling round wire on spools. I can easily find the
smaller gauges spooled, but not anything above 19ga.
Why might I need such a thing? Well, I use a couple of hundred ozt
of wire every month and need to have it wind off the coil easily at
high speed. With a typical coil, I have to use an improvised spool
onto which I slip the coil. The tough part is that the wraps around
the coil can be overlapped and cause a heck of a tangled mess as I’m
winding off. Spooled wire is by its nature nicely wound and makes it
much easier for me.
Thanks for any advice!
Regards,
Tom Colson
