[Source] Silver micro bolts & screws
I am looking for a source for tiny silver micro bolts and screws for
cold connections. Does anyone know of a source for these?
Thanks!
Sally
Sally
it’s the best way to make your own and make sure that the silver
that you are using it contain little bit of nickel
Raffi
Hi Sally,
I don’t know of silver nuts and bolts, but there is stainless steel.
I would recommend J.I. Morris Company out of MA.
http://www.morris01550.com
Reba
Hi Sally…Reactive Metals carries silver and gold plated micro nuts
and bolts. http://www.reactivemetals.com
Regards,
Beth Taylor
Actually Sally, if you don’t plan to use a lot of them, I would say
make your own for the job at hand. You can pick up taps and dies for
just a few dollars and simply thread the proper size wire for the
screws and tap the proper gauge sheet for the bolt. Just a
suggestion. Check the Rio catalog or MicroMark.com for the materials.
Cheers, Don in SOFL
