Anyone know sources & suppliers of ready-made granulation beads in
different sizes?
I do NOT want to make my own beads.
Granulation beads the following materials:
14K gold
18K gold
925 Sterling
925 or 970 Argentium Silver
Jon
different sizes?
14K gold
18K gold
925 Sterling
Jon
Hi Jon,
Stern-Leach makes Argentium Silver granules. Rio Grande carries
them.
Cynthia Eid
Here’s the stock numbers and sizes of the Argentium granulation
beads we carry.
103-240 GRANULATION BALLS ARGENTIUM S.S. 0.4MM-0.5MM 1 OZT
103-241 GRANULATION BALLS ARGENTIUM S.S. 0.5MM-0.6MM 1 OZT
103-242 GRANULATION BALLS ARGENTIUM S.S. 0.6MM-0.7MM 1 OZT
103-243 GRANULATION BALLS ARGENTIUM S.S. 0.7MM-0.8MM 1 OZT
103-244 GRANULATION BALLS ARGENTIUM S.S. 0.8MM-1.0MM 1 OZT
Sincerely,
Thackeray Taylor
Rio Grande Technical Support
800-545-6566
505-839-3000 ex 13903
technicalsupport@tbg.riogrande.com
No company I know makes 14k or 18k or 925 sterling granules. You may
need to hire someone to make them for you.
If I were you, I’d re-think the value of having 925 sterling
granules because fine silver granules or Argentium sterling granules
are far superior even on 925 sterling sheet metal. Fine silver
granules and 22k gold granules are available from SPM.com. Rio
carries Argentium sterling granules.
Nancy
No company I know makes 14k or 18k or 925 sterling granules. You may need to hire someone to make them for you.
It is possible we have a language problem here… Maybe those of you
who have responded to this post read it right, but I thought it
meant granulated beads, not granules. Jon?
Noel
I think if one were able to make and work with them, granules of
sterling could be quite and interesting design element. You would be
able to blacken them to make them stand out. It could be pretty
Kim Starbard
http://www.kimstarbarddesigns.com
Try cutting a small piece of wire and melt it to get the size ball
you need and then write down the gage and length of the size ball
you want. Graduated ball can be achieved by cutting back on the wire
and you can graduate your project from a larger bead to a finer bead.
think of a rams horn with it’s curl and place your largest beads at
the base and start graduating them down to the tip, holding the
curvature that you want. Ideas make beautiful jewellery and make you
feel good too.
Good Luck, Stephen
Noel
It is possible we have a language problem here... Maybe those of you who have responded to this post read it right, but I thought it meant granulated beads, not granules. Jon?
I was asking about spherical balls of metal to be used for
granulation - are these called granulation beads or granulation
granules?
Jon
Fine silver granules and 22k gold granules are available from SPM.com. Rio carries Argentium sterling granules.
Sorry I listed an incorrect address for SPM. The correct address is:
SPM (Semiconductor Packaging Materials Co., Inc)
1 Labriola Court, Armonk, NY 10504-1336
(914) 273-5500 Fax: (914) 273-2065
http://www.sempck.com
Nancy
Hello
If I were you, I'd re-think the value of having 925 sterling granules because fine silver granules or Argentium sterling granules are far superior even on 925 sterling sheet metal. Fine silver granules and 22k gold granules are available from SPM.com. Rio carries Argentium sterling granules.
regarding granulation supplies a web address of spm.com was given by
someone, this leads to a pest control site. Can anyone give the
correct web address please. Or any other source for 18ct 22ct and
sterling granulation beads.
Thanks
Phil W
