Soldering Question [ was:Firestain]
KIln Soldering Question?
What would direct the flow of the solder to the hotest part of
the joint?
Bill
Ginkgo Designs
@WILLIAM_I_EISENBERG
the joint?
If the joints are close fitting, the solder should flow into
them by capillary action.
Rick Hamilton
Richard D. Hamilton
wax carving, modelmaking, jewelry photography
http://www.rick-hamilton.com
@rick_hamilton
Hi,
Try anti-flux painted in a ring around the joints.
Skip
                                  Skip Meister
                                NRA Endowment and
                                   Instructor
                                @Skip_Meister
                                09/03/9701:16:58
 KIln Soldering Question? What would direct the flow of the
solder to the hotest part of the joint?
Do kilns have “hot spots?”
Hi,
In-furnace soldering is a technique used extensively in
dentistry. Once porcelain is applied to a restoration, direct
flame soldering will ruin the ceramic so many techs
in-furnace(kiln) solder. The pieces are joined in position with
sticky wax(burns out clean) or Duraly( a dental acrylic made for
casting small inlays in the direct mouth-to oven-to cast-to
mouth technique). It is invested in soldering investment and
when the joint area is burned clean, the liberally flux-coated
solder is placed carefully and the piece is slowly brought up to
temp of solder flow. Don’t rush it. If solder refuses to
flow, a gentle tap with small metal tool on the investment
will usually usually do the trick.
The Duralay which I mentioned is a marvelous product. It is a
powder (polymer) /liquid (monomer) that when mixed together will
produce a hard acrylic that can be used to make small parts
(carved with burrs, or when impressed and used as a mold can be
waxed into). It burns out clean at 1000 F. Any body wanting
more info can E-mail me.
Regards,
Skip
                                  Skip Meister
                                NRA Endowment and
                                   Instructor
                                @Skip_Meister
                                09/04/9713:07:14
