Silver solder can be hidden on a copper piece by copper plating.
Simply place the piece in blue, copper saturated pickle with a piece
of iron or any ferrous metal. This creates a charge which will copper
plate all items in the pickle at that time. Remove the iron and the
solution is still usable for silver and gold pieces.
Silver solder can be hidden on a copper piece by copper plating. Simply place the piece in blue, copper saturated pickle with a piece of iron or any ferrous metal. This creates a charge which will copper plate all items in the pickle at that time. Remove the iron and the solution is still usable for silver and gold pieces.
Thank you Amy I forgot that trick with the iron for transfering a
copper color over silver solder, could have used this last week - made
a copper bracelet small round copper wire rings inside a larger circle
soldered - I used a red heat patina, then burnished with Stainless
shot in the tumbler - it worked Aileen
