Hi Alma,
I’ve made every darn mistake on copper that can be made. Background
on me, Spent many years as one of two artists in residence during the
summers with the Utah Shakespeare Festival. I did old Renaissance
metalsmithing demonstrations on stage. I’ve gone through the Revere
Academy, and the Tenn. Tech Universities Appalachian Craft Centers,
metalsmithing program.
I was taught the proper ways of dealing with copper and other
metals.
Copper is a metal unto itself. Many of the old ways, I’ve found
funny ways that they do not always work on copper.
Case in point. You DO NOT have to clean copper to do a solder if you
use the high bearing copper solder that is available at Rio. I’ve
tried them all, and this solder doesn’t use flux. Yes it can be grey
colored if you do not handle it post soldering properly. Here are a
few of my secrets for soldering complicated copper pieces. Only use a
bench knife or scraper and carefully scrape the surface of the piece
on the area you want to solder.
The rest of the muck will act as a nice resist. No need to use
yellow ochre. It also holds the other parts in place if it is a
complicated piece. DO NOT pickle between. I make complicated 3-D
swans in large scale out of flattened 6 ga. wire. Never have I had
them fall apart when doing repeated solderings.
Next don’t use spare or that kind of pickle. Use a nicer gentler
type.
Use Rio Pickle (I stop and get the 5 gallon drums when I go cross
country) There are others out there with the same type of
formulation. Next loose the steel wool. Just anneal a bunch of copper
and pickle the pieces before you work them. The pickle will then
charge itself. You have no idea what other contaminates are in the
steel wool. That can effect the way it will plate the piece of
copper. I’ve found a nice deep blue colored pickle will cover any and
all solders that I’ve used on copper. It is hard to blast off and you
would have to sand the hell out of it to get rid of it.
I have a chem degree, but it is in molecular bio chem. At the time I
was getting it 20 years ago, I wanted to be a Dr. But a mother of
teenagers should never have that goal. I can’t site the proper
mechanics, but give me my old texts and I can easily find it.
Copper is cheap and easy to work if you know how. Practice with it.
If you want some of the Rio solder to try, email me off list and i
will send you some. There are a bunch of copper solders out there
that promise a lot, but I’ve found them more fiddly. Also get a good
supply of iron wire that you can use to bind you cones with. It helps
to hold them in place.
Conversely the properties of copper are such that when it is heated
to temp, that same tech can help it close inward. You will need to
find something (metal) like crumpled old scrap copper to hold it up
from the inside. I have a bunch of old yard sale solid steel knives
that I use to hold things and fill them if I need more.
Lots of good help on this site. Mine is just another view and
opinion.
Aggie Missing my mountain top this summer.
