Mindy… You are probably not getting it hot enough. When you have
something as big as I imagine a lantern is, it’s going to be a bear
to heat up enough to get the solder to flow. What kind of torch with
what size tip are you using? What’s the thickness of the metal? You’d
be surprised at how much heat you have to use on copper to get it to
flow sometimes. Copper just loves to soak up and luxuriate in the
heat. I do some sculpture pieces with scrap copper and I use an
acetylene torch with a tip big enough to melt ingots because it takes
that much heat to solder a 6 gauge wire a flat piece.
Are you sure it’s really copper that you’ve got there? It could be
something that looks like copper but is really an alloy that is going
to make it impossible to solder. Also, what kind of solder are you
using? (silver? paste?, etc.)
Do you really have to solder it? Why not rivet it. You could add to
the beauty of it with some nicely finished rivets. You could use
large gauge wire and form the heads. It could be super cool. You
could assemble it with copper screws and nuts which could add to the
beauty of the piece. You can get small copper screws and nuts at a
decent hardware store.
Sometimes I get an idea in my head about how something ought to look
and I will go to ridiculous extremes fighting to make it the way it
should be. When I give up and realize it’s never going to do what I
want and just go with what it wants, then I usually end up with
something I didn’t expect but like better. Now may be the time to
compromise on this item and think outside the box.
Mardel
