Hello,
Can someone help me?
I want to solder bronze (87 Cu : 13 Sn) and I want a reasonable
color match.
Does such a solder exist and if so, what is its composition?
Many thanks in anticipation.
Robert
Australia
Hello,
color match.
Robert
Australia
Probably the closest match is a cadmium bearing solder CD-35
or the cadmium free version. see the pdfs under silver alloys at:
http://www.brazing.com/products/Braze_silver/
The pdfs may take a long time to down load ,but they show a wide
range of alloys. They are not all easy to buy in the US in small
quantities
what you want is a high copper content silver alloy… The 35 has a
wide mushy range which may be desirable or not. The 45 silver has a
narrower melting range and is more fluid but not very brass
colored
I have some other US sites –
For cast sculpture we use Everdure silicon bronze and gas or tig
weld with the same filler material.
I haven’t worked with the tin alloys.
jesse
I want to solder bronze (87 Cu : 13 Sn) and I want a reasonable color match. Does such a solder exist and if so, what is its composition?
Try the various brazing rods available at your local plumbers’
supplies.
Brian
B r i a n A d a m
e y e g l a s s e s j e w e l l e r y
www.adam.co.nz
