Help! I want to add a row of small pearls to the outside of a
hoop earring by threading them on wire through several small
wire circles spaced evenly along the hoop - probably 5.
How can I get these smaller circles soldered on so they stand
evenly? I plan to use about a 15 gage round wire or possibly a
flat piece, but the problem remains as to how to get the little
circles done nicely. Thanks. This site is so great with so many
people sharing the info.
Cecelia,
A friend of mine always uses regular casting investment to embed
small pieces and stabilize them for soldering. It works great
from what i’ve seen you might give it a try. Mix the investment
in a flat dish and as it begins to harden embedthe pieces in
position being sure not to get investment in the joints, and
solder when dry. good luck and let us know what finally works.
Framk
Hi Cecilia,
Here’s one way you might try.
Lay the large hoop out flat on a magnesia fire brick (they’re
the soft ones). You may want to secure it with several pins.
Determine the positions for the small rings.
Using a small screwdriver or some other tool make a hole in
the brick. The hole should be located where you want the ring to
attach to the hoop. Make the hole just wide & deep enough to hold
the ring at right angles to the hoop with the joint next to the
hoop.
Position all the rings (or as many as you feel comfortable
soldering at once) & solder.
Good luck!
Dave
