I am going to solder a charm holder onto a 5mm wide 14ky gold comfort
fit band. Since I am soldering a piece of 2x2mm square wire (half
circle) onto the ring so that I can attach a charm, what is the best
procedure to use so that I don’t melt the wire and get the ring hot
enough for the solder to join the two pieces?
Thank you in advance,
Susie Morgan
Elegant Metal Creations
Susie,
Try heating up the ring well first, even pre-flowing (partially) the
solder just on the ring, then move the wire into place (make sure it’s
already fluxed) & let the solder re-flow, making the join.
Lisa
Designs by Lisa Gallagher
www.designsbylisag.com
Hi Susie,
To avoid melting small parts like wires (especially the end is not
attached to anything), don’t heat the parts directly with burner as
far as possible.
If the parts are fixed firmly, you can protect it by covering with
another metal such as titanium. First make some different size of
titanium cover coil by winding titanium wire, and then cover the
precious metal wire with a suitable size coil. I don’t know the reason
but titanium doesn’t be soldered.
If the parts are not fixed firmly, the above method is not available.
I recommend to use some cooling substances. There are some cooling
substances to avoid conduction of heat, or to cover the surface like
putty. But I don’t know the English names of such substances. The
former is like borax, and the latter is powder of grind stone that is
used by being dissolved with water. When using these you have to take
care not to mingle with borax.
But the most important point is to heat the place a little away from
the easy-to-meling place and put the solder when borax becomes like
melted sugar (but the color is clear).
Takashi Tomoeda @Takashi_Tomoeda
