Hi Everyone…
I just started a new job as a bench jeweler and I am having a few
issues with my solder. When I go to heat and ball up my solder, the
solder quickly gets red hot and tacky / sticky. When I remove the
flame, it cools and turns grayish in color. In the past, I had this
problem at home with some silver solder and thought it might be my
torch because at work I had no problem soldering. I took that solder
home to test my theory and it turned out to be the solder with the
problem.
Now, I am having the same issue with both 14k yellow gold solder and
sterling silver solder. I have always used oxy/propane but the shop I
just started at uses oxy/acetylene so that is something I am
adjusting to. I am also using the little torch instead of a larger
torch. The solder is from Stuller and comes in little chips in
plastic tubes so I am thinking that is not the problem. Is it
possible I am heating the solder to quickly? I’ve tried adjusting
the flame to no avail. I’d appreciate any input. It’s really quite
frustrating not being able to solder jump rings closed.
Thanks!
Adam
