i have recently purchased some solder filled silver wire from rio
grande to make a half persian 4 in 1 style bracelet for my wife.
the bracelet will be made completely out of 20g hand sawed jump rings
with a diameter or 3 mm that i have cut with the finest jeweller saw
i could find. i have never made any jewellery before but am pretty
proud of the bracelet that i have put together. all that i need to
do now is to solder all the links together. this is why i bought
the solder filled wire. i was under the impression that once heated
the lliks would all self solder and i would have a nice strong
bracelet. but this does not seem to be the case. before
experimenting on the bracelet i decided to try and seal a few loose
links. i am using a disposable propane brazing torch like the ones
used for plumbing. so far the only thing i have been able to do is
melt the rings. i heat them up until they glow and check them but
they are not sealed. i keep trying letiing them glow a little
brighter but still no luck. finally they melt. i have the rings
butted as closed as much as possible. and are held closed by the
little bit of tension or spring that the metal has. i am frusterated
and wondering it anyone can help me. is this something that i can do
with a torch or is there another way to do this without destroying my
bracelet or wasting the money i spent on the wire.
please help me
Mark
