I have posted before regarding my acquisition of a smith little
torch, but I have one more question so please bear with me. There
are two gauges on each tank, oxy/acetylene. What settings should
these gauges be set at?
Thanks again for your help.
Gerry
Try this link: http://www.littletorch.com/help.html#lit
It’s the complete FAQ for the Little Torch on Smith’s website,
including recommended pressure settings for the tips.
@Ron_Charlotte1 OR afn03234@afn.org
Gerry,
That depends on which size tip you are using. On tips 1 - 3 I use 5
psi for acetylene and 6 psi for oxygen. For tips 4-5 I use 6 psi for
oxygen and 8 psi for acetylene. I also have a multi-tip with 4
orifices and use 10 psi for acetylene and 14 psi for oxygen.
Joel Schwalb
@Joel_Schwalb
www.schwalbstudio.com
