Small kiln and melting furnace on same circuit
I’ve been doing lost wax casting with a small table top kiln for a single flask. I use a little smith torch with rose bud tip to melt either silver or bronze.
I was thinking of adding a melting furnace to my equipment since my rose bud tip is having trouble melting anything around 250g.
I have my whole setup in a corner of my apartment so I was curious if a melting furnace could even run on the same circuit as the kiln?
Look at the wattage. 1500 is likely your limit on one circuit unless is is a 20 amp circuit.
Ha yup they both can’t be on a standard circuit.
Looks like I have to find a bigger torch :stuck_out_tongue:
Hi,
interesting question! thank you for asking it!
Julie
