Hello all, I lost the post in which someone was asking about cutting
a pearl in half for earrings. Didn’t see any responses to it either.
maybe my eyes and mind are being affected with all this Xmas order
overload! I have cut a number of pearls for this reason. Here is a
quick description of how I do it: Mark where you want to cut, usually
with a pencil. Cut some narrow masking tape strips and wrap around
pearl leaving your markings visible(a few millimeters)then wrap the
rest of pearl with more tape. This helps hold it in place in a pearl
holder(you can modify a clothespin) and secure pearl in that,
wrapping either more tape, wire or rubber bands to keep pearl from
slipping(very important!). I gingerly use a separating disc with a
low RPM to make initial cutting line, frequently dipping in water, I
then alternate cutting with disc and fine toothed small saw blade in
jeweler saw frame. A thin diamond impregnated disc is useful too.But
the are not as thin as separating disc, and only on large pearls.
Chinese freshwater pearls that are tissue nucleated are the easiest,
for they have no shell bead nucleus, which is harder than the pearl
nacre. Some pearl nucleus(bead from another mollusk) are not ‘fixed’
in the pearl, and will ‘roll’ as you cut them.This happens when
drilling pearls too. This can be a real problem, and the only way
I’ve gotten around it , is to cut all the way around the pearl to
the loose nucleus and the split the halves apart from nucleus. You
may want to try on a damaged pearl first. Keeping the pearl cool and
your fingers out of the way help! Good luck
Thomas Blair Designing Goldsmith JA* Certified Bench Jeweler Designing
Jeweler Island Gold Works Hilton Head S.C. 843-686-6001 843-686-6407
fax
@Island_Gold_Works www.islandgoldworks.com
