Is there a simple way to bulk clean silver? I have a mix of silver
and silver plate spoons, dishes, etc that I’d like to dump into a
pot to clean enough to see if they are worth more time and effort.
Thanks,
Bobi
Thanks,
Bobi
some one will surely know the recipe for exact recipe, it involves an
aluminum pan…or a glass one with aluminum foil in it, and washing
(not baking) soda. cleans it in a snap…it may even be archived.
mary
Hi Bobi;
This has probably been covered before, but try this. Get an aluminum
pan, any kind, and fill it with very hot water. Stir in a couple
tablespoons of washing soda. Put the silver in, making sure it makes
contact with the aluminum. Works great, just make sure the silver is
free of grease and oil. Washing soda is a bit hard to come by these
days. It used to be in the laundry supplies section of most grocery
stores, but people don’t use it much any more. You’ll have to try a
few places. Baking soda won’t work.
David L. Huffman
Washing soda is a bit hard to come by these days. [snip] Baking soda won't work.
Actually, it worked for me…
Noel
Arm & Hammer sells washing soda on line, small packages or large:
soapsgonebuy.com
Wayne Emery
The Gemcutter
I’m sure I won’t be the only one with the “recipe” for cleaning
silver but I have a card with this recipe that I give to all who
purchase my chainmaille for making their silver sparkle like new…
My deceased mother-in-law cursed me with a silver tea set and it even
works for that. I just have to use the kitchen sink instead of a
bowl.
Line a container with aluminum foil, shiny side up. Depending on
size of container and number of pieces, pour 1/4 to 1 cup (don’t
measure, just estimate) WASHING soda in container. (Made by Arm and
Hammer, it is found in the washing detergent section of grocery
store. You can use regular Arm and Hammer cooking soda but it’s not
as strong and doesn’t work as well.)
For the tea set in the kitchen sink, I probably use 2 cups of the
soda. Fill the container with boiling water; drop in silver. (Or vice
versa–it doesn’t matter which you do first.) In 10-15 minutes, your
silver should sparkle. The tarnish and discoloration migrates to the
foil. Since I was an English major in college and failed all science
courses, I can’t explain why this works, but it does! I promise!!
One caveat–Do NOT use on pieces that have been deliberately
“patina-ed” or patinated."
It will also remove that.
Ann L. Lacava
158 Overton Lane
Powell, TN 37849
865-938-4180; 865-776-3902
www.PureSilverStudio.com
Funny, but I have been doing this with BAKING SODA for quite a
while, and it works very well. Have I been holding my mouth
different of something?..
Allan Beck
Boise, Idaho
Washing soda is a bit hard to come by these days. It used to be in the laundry supplies section of most grocery stores, but people don't use it much any more. You'll have to try a few places. Baking soda won't work.
My favorite source for washing soda, aka soda ash:
http://www.dharmatrading.com Lots of other cool things, too!
Lisa Orlando
Albion, CA, US
Is this method safe for silver plate?
Thelzeda Moore
Occasionally someone askes this question–it’s now MY occasion. Will
someone please post the method for mass clean/restore polish to
tarnished silver? It involves shiny aluminum foil and some solution.
I believe it has to be heated. Also, would a shiny aluminum foil
baking pan do the same job as lining a container with foil, shiny
side up?
Thanks folks,
Joyce
Crumple foil slightly and put the piece on it then add hot water and
Calgon water softener
Also, would a shiny aluminum foil baking pan do the same job as lining a container with foil, shiny side up?
The tarnish migrates into the creases in the foil (or at least it
did for me), so I am not sure there is good reason for using the
baking pan. I use a glass or plastic container.
