The heat makes the crystals (grains) of the metal enlarge and
migrates brittel (copper oxides) towards the grain boundaries thus
producing a three dimensional 'lace' of stiffer materials at the
outsides of the grains. Thus the whole piece gets harder. I suspect
it might contribute to fire scale (don't know)
Close, Charles. Not quite, though.
The heat does indeed cause grain growth, though at these lower
temperatures, usually that’s not all that much. Precipitation
hardening works because the metallic copper is not actually properly
soluble in the gold or silver at lower temperatures, and at these
temperatures it’s mobile enough that it can come out of the forced
solution (forced there just because it’s soluble in the molten metal
and at high temperatures, but doesn’t have time to come out of
solution in normal cooling of a casting piece of metal or working
it. Annealing, for example heats the metal high enough to again
dissolve the copper in the gold) the hardening that results from
precipitation hardening is because the copper, coming out of
solution, forms new crystals of copper along the grain boundaries
between the gold crystals.
Metals deform with two mechanisms. One is that due to the atoms
literally sliding along the slip planes within the crystals
themselves, the crystals can be very much deformed. But for a whole
mass of metal to deform, not only must the crystals deform, but the
boundaries between the crystals must also stretch and deform to
follow the deformation of the crystals themselves
The boundary between like crystals is far more able to deform than a
boundary between unlike crystals, so the formation of different
crystals, in this case copper, along crystal boundaries, then means
that even if the crystals themselves are soft (copper is, of course,
soft), the boundaries between the crystals cannot so easily stretch
and deform to follow the deformation of the crystals themselves. This
then keeps the whole mass of metal from deforming.
There shouldn’t be copper oxides within the body of the metal.
That’s not what’s migrating around in precipitation hardening, at
least not what the intent is. Regarding fire scale, If you harden the
metal in an “air” environment, oxygen will penetrate into the surface
of the metal, and if it meets copper, will combine with it. The
resulting copper oxide tends to migrate to the surface if it’s near
to it in the first place, (at elevated temperatures, any of the
metal ions tend to migrate around, the mechanism of diffusion
bonding, for example) If it reaches the surface, it stays there,
since the oxide isn’t as able to rediffuse into the alloy, so it
builds up on the surface. . So yes, precipitation hardening can
cause fire scale, but the mechanism of that is slightly different,
and need not happen if the surface of the metal being hardened is
protected from oxygen.
Peter
