I recently stumbled across a bottle of Silver Plating Powder from the
COOL-CMF company of Portland Oregon. Can you tell me anything about
this material. For example; what is the likely chemical composition,
does the company still exist, if so, do you have any contact
Anything you can tell me would help.
Thanks,
Bill Buyers
@Buyers_Bill
Cool Amp is used to resist high amperage connections on current
transformer cables. Cool Amp claims the silver plate is permanent and
will not peel off indoors or out. I have used it in conjunction with
PNP paper to silver plate a copper table top. You apply the power with
a soft cloth dipped in water than in the powder, rubbing in a circular
motion until the metal is plated. Be sure to clean the metal well. It
silver plates copper, brass and bronze.The table I plated is a
sculpture and not used like a functional table so I don’t know how it
holds up under usual wear and tear. The table is three years old and I
see no change except the silver has tarnished. I’ve attached a picture
of the table hope you can open it. Their address is:
Cool-Amp
15834 Upper Boones Ferry Road
Lake Oswego, OR 97035
(503)624-6436
Good Luck,
Dolores
** Atachment Removed **
