A question for all you shakudo artists–
Since shakudo is mostly copper, does it tend to turn the skin
green like copper if you wear it?
Virginia Lyons
Metalsmith
Virginia Lyons
Metalsmith
A question for all you shakudo artists-- Since shakudo is mostly copper, does it tend to turn the skin green like copper if you wear it?
Virginia, I wear spectacles made from 12% shakudo and while they
do not touch my skin very much (only around the bortom of the
eyewires where the metal goes blacker) the shakudo does not go
green. I wear them every waking moment of the day, which these
days is not saying much
Interestingly, the optical findings I use for nosepad brackets,
made of a nickle/copper alloy, they do go green. I have to scrub
the loose bits of green gunge from the findings every few months.
I made some rings from 10% shakudo and they turned the skin
black underneath. Not a good look.
But green? No.
Brian
B r i a n A d a m J e w e l l e r y E y e w e a r
ph/fx +64 9 817 6816 http://www.adam.co.nz/4.htm workshops USA May/June:
Maryland College of Art; 92nd St Y NY; Revere Academy CA;
Arizona Designers Phoenix; Estes Park CO
Last week, a member of Orchid asked if Shakudo got your skin
green or not. I only found one answer to this question, I am
interessed to have another advice, as I’m planing to make shakudo
to make a ring. Thank you for your answers. CAMILA
