Hello,
may i make a suggestion?…perhaps since you are new to learning silversmithing, you might enjoy the challenge and practice of fabricating and soldering your own settings, as well as learning how to set stones.
since you are cutting and faceting your own stones, this will afford you the flexibility to make settings to the specific measurements of your custom stones…
you can make basket settings using round wire…
you can make collet/ crown style settings using sheet strips
you can make bezel settings using both sheet and wire, or sjust sheet and cut a bearing seat with a bur
skills learned would include:
calculating metal lengths to fit stone circumferences
considering the side profile angles and spec measurements you desire, and how to achieve them
soldering practice on successive, multiple joints using multiple solders (hard, medium, easy)
learning to work with small components, problem solving “holding” challenges
filing to fit pieces together
binding/ holding workpieces for soldering
filing/ cleaning up/ finishing/ polishing small areas
preparing stone seats for setting (Prongs, bezels)
a great online resource for stone setting is jewellerytrainingsolutions.com.au
https://www.jewellerytrainingsolutions.com.au/
the all access pro monthly subscription, is about $40/ month
can cancel at any time
there are a few different skill level based subscriptions
culminating, each offering successively more advanced categories…
or you can purchase 12 month access to specific videos
also, YouTube has many free videos
try searching
peter keep/ jewellery training solutions
lucy walker jewelery training
melissa muir
andrew berry/ at the bench
nancy l t hamilton
rio grande
julie
julie
