I’d like to set some flat stones from the back so I can put small detail pieces in the front bezel edge. How is this kind of setting done?
Thanks,
Jan
Thanks,
Jan
I have just soldered a bezel in the back or used prongs and tabs. You need to be careful that there is a smooth transition from the outside edge of the setting to the stone surface. Good luck…Rob
Hi,
do you have some sketches or photo of what you eould like to creste?
could you can upload?
upload from your phone using first icon below right.
julie
I have set a number of stones from behind, but apparently never bothered to take pictures. Following is the best that I can offer. It is a very thin Lapis cab riveted between two discs. The top has hole in it and it is contoured to follow the curve of the stone so that there is a smooth transition between the edge of the stone and the bezel…Rob
