Did I real that post right? Did Leonid imply there was a lack of
durability in opals and hence they were not LOL how
durable are natural emeralds?
Quality Opals are equal in visual impact to any other fine stone.
I have not read much here really relevant to opal setting, so lets
do Opal Setting 101 for a pendant.
Opals are not constructed from crystal structure, the stones are
made from small spheres which are easy to separate or crack.
Opal setting is a specialized skill. For me it is ten times harder
to set an opal than a round 1 carat diamond.
Opals are cut en cabachon to maximise the stone. Hence they are
often in ‘freeform’ shapes or cabs.
They, unlike the diamond, are not computer precision cut.
Hence the back of the opal is usually uneven!!!
It takes a long time to set an opal.
Have frequent brakes this could be very nerve wracking.
Make your bezel from.8mm thick fine silver or gold and as wide as
the stone is high.
It should be big enough to allow you to easily pass the stone
through the bezel. Opals do not like being pushed around. They can be
broken more easily than turquoise or malachite.
Now you have your bezel. You have to make the seat for the stone.
Get a strip of.8mm square wire of the parent metal as long as the
bezel.
Now the ‘fun’ starts. Fit the.8mm wire into the inside of the bezel.
Cut to size and solder. Alloy to cool before pickling.
Now you have a bezel and a piece of.8mm square wire the shape of the
bezel that fits tightly into the bezel, this is the seat for the
stone. Push the wire into the bottom of the bezel.
Now the xtra fun starts. Place the stone with the bezel around it
face down. I use a rubber bench pin for this.
GENTLY push the wire down till it conforms to the shape of the
stone. You may need to burnish the wire back to the sides of the
bezel. This depends on how far you have to move the seat, the
deformation of the wire may pull it off the sides. This is why fine
metals are use they are malleable.
Solder the wire seat in. Solder on bail etc. Clean up and bring to
final polish and clean.
Now you have a bezel with a seat that fits your stone. If setting a
cab some filing may be needed to bring the bezel height down. This
is a metal sacrifice due to the process of getting the seat to fit
the stone.
If you have a freeform stone you need to file the bezel to the
contours of the stone. Yes metal sacrifice makes opal setting
expensive.
Put the setting on your bench pin and put in the stone. Use a bezel
pusher, for a cab use usual setting sequence. But check with a loupe
frequently. When the metal is down on the stone leave it for the
moment.
With a freeform stone start pushing from the Corners.
When the bezel is down clean up tool marks.
Burnish the metal to make it gleam, this takes TIME and louping.
TAKE TIME AND CARE AND YOU CAN DO IT!
TTFN
Richard
