Continue from:
New Colors in Jade?
Serpentine is indeed olivine, and good olivine/serpentine can be translucent and have a 'ring' like jade but is much softer. It can be scratched with a pocket knife and even carved with good files, yet it can also take a good polish using tin oxide on leather at about 600rpm. There is a deposit just on the edge of Nelson city that used to be quarried and crushed for use on agricultural land deficient in magnesium, and used to be used in road making too.
I don’t think so, John. There is a high-grade rather hard variety of
serpentine called bowenite, that is translucent and makes a pretty
good substitute for jade, but it’s not as hard as olivine; it tops
out at 5.5 on the mohs scale (which is harder than most knives,
although files are harder). See
http://www.emporia.edu/earthsci/amber/go340/gb4.htm
In its crystal form, olivine is known to jewelers as peridot, which
is 6.5 to 7 on the mohs scale - a knife won’t scratch it. It makes a
nice clear green gemstone, and is hard enough to facet and set in a
ring. Jade (nephrite and the harder jadite) falls in between these
two in hardness. For more info on olivine/peridot see
http://ist-socrates.berkeley.edu/~eps2/wisc/oLect14.html
Olivine sand is hard enough to be commonly used for abrasive
blasting; most serpentine is quite soft; this depends on the
proportion of its two basic constituents.
Andrew Werby
www.unitedartworks.com
