I am new at this, but here goes. I am pretty much a self taught metalsmith and jewelry designer; at the present I am interested in expanding my skills by doing some engraving. I am interested in purchasing a power assisted hand engraver, either the GRS GraverMach AT or the Foredom PowerGraver 2293. I would appreciate some opinions from experienced engravers as to which one I should get. Thank you in advance for your advise.
In reading over the posts on this thread I noticed that no one fully
answered your original question about the GRS system compared to the
Foredom system.
Your question boils down to these two choices; an electric motor
with a dedicated hammer hand piece, versus an air powered hammer
handpiece. I haven’t used the Foredom PowerGraver, but I have
experience with a flexshaft and hammer hand piece (several different
ones) that I would assume would be very similar. I also have a GRS
system and a Lindsay Air Graver. For brute hammering and metal
removal, the Foredom system would probably be the strongest, followed
by the GRS, then the Lindsay.
For finesse, the Lindsay has the edge over the GRS (in my very
humble opinion), but both probably have it hands down on the Foredom,
mainly due to its handpiece design. The handpieces of both the GRS
and Lindsay are mushroom handled gravers with an almost identical
feel to a hand graver, in fact, lift your foot and either one IS a
handgraver. The handpiece of the Foredom appears to be similar to the
first air powered handpiece, the GRS GraverMeister, which came out in
the early seventies, if memory serves me right.
The problem with that handpiece design is that the hose or cable
comes in through the very end of the handpiece, right where your palm
ought to be. It makes holding and using it as a graver very awkward,
nearly impossible even, and partially explains why so many old-school
engravers dislike the air powered tools so much. First impressions
can be that lasting.
The big question you were asking (I think) is whether an air powered
handpiece is a better investment than the Foredom. I would say yes,
it is, especially if engraving is your primary motivation.
I use a Lindsay Air Graver. It is probably the most used tool on my
bench, there is rarely a piece I work on that I don’t use it
somewhere. Before the Lindsay, I used a Graver Max and used it every
bit as hard as the Lindsay. An air powered graver is an almost
indispensable bench tool once you start using one, even if you never
engrave a single line. If it were my choice and the difference
between two grand (don’t forget the compressor) and $400 wasn’t a
major issue, I’d take the air graver over a hammer hand piece in a
heart beat.
You have to decide what you are going to use it for and how much you
can afford. It may be that a new hammer handpiece for your flexshaft,
a few hand gravers, some Chinese white, a block or something to hold
the work in or on, a stone and sharpening jig, a couple of pads of
tracing paper and a nice drafting pencil might be your best
investment. If you have decided to get into engraving and want to use
power, use air if there is any way you can, and look into the Lindsay
as well as the GraverMach. They appear similar by casual observation,
but they are very different in both design and operation.
Steve Lindsay also offers sharpening jigs and stones in sets that
are pretty slick (non-powered in case you were wondering). They can
flatten out the learning curve of sharpening pretty quickly and let
you keep the finesse of hand sharpening intact. GRS is another great
company that offers pretty much anything you would ever need when it
comes to engraving (except Lindsay’s stuff of course).
Good luck Marie.
Dave Phelps
