Hi, I recently purchased some argentium silver to give it a try and I’m wondering what to do with the scrap. Some of it went into my sterling scraps by mistake and I’m wondering if this will reduce the value when I bring it in to be melted down. Is it ok to mix it with the sterling or should it be kept separate?
Hi Michael - your scrap is still sterling even if it does have some
argentium in it. Regular sterling is usually 92.5 per cent silver and 7.5
per cent copper. The Argentium people have replaced some of the copper
with some germanium. The people who buy your scrap are interested mostly
in the silver content and that is still 92.5 per cent. By the way - how
did you like it?
Barbara
Thanks Barbara. I liked it it’s easier to solder than Sterling and and seems to be cleaner somehow. I also liked the fact that it can bond together. When I was making and oval bezel setting, i just laid two strips on top of the other, heated it up and didn’t even bother with solder. Pretty cool.
Do you sell your scraps? I just melt mine down and reuse it. I don’t use anything less then 925, or 999.
When working on something I start with a clean area and save the dust and scraps in a jar, then when I get enough I will melt them down in my Cruicible and pour it into a mold. Saves shipping and I find it’s fun to do.
I just wait until I have about a KG and take it in to be repurposed into various plate, round and half round sizes. I dont bother with the shavings but might start doing this
Scrapping your own silver is better, only if you are able to do it! By
sending it off to a refiner you will loose about 5-7% refining fees. I use
my own refiner as I get back .925 silver then my caster can cast without
any pin-holes. I want clean .925 for my silver rings & not melted scrap, or
a mixture of some other alloys.
