Sanding mandrel
how do you keep sandpaper on a sand mandrel?
What does the mandrel look like?
It has a cut down the middle. thanks Christina
Hi Christina,
Is this the type of mandrel? and does this video help?
Don Meixner
What I do is fold over the very end of the sand paper and I force it into the slot. Thinner stuff you have to fold over twice. You can cut the mandrel shorter also for better control
I load sandpaper just like scavengerqr. I precut sandpaper and polishing papers using an old paper cutter so it’s always ready to use.
If you want to save a few dollars it’s a simple enough tool to make. Just cut the head off of a 10d common nail, saw a slot down the middle and then cut to length. Using nails of different thicknesses you can make several in several sizes for just a few pennies. :wink:
For all it’s worth, FYI: Carpenter’s use “Sanding Paper”, WE use 'Emery paper"…:>)
gerrysdiamondsettingessays.blogspot.ca (<= This is my blog address!)
***Gerry Lewy ***
Toronto.
Thank you all! Your replies were very helpful, I appreciate your help. Christina
Elliot- Ha! Until about 5 years ago I never used a fancy store bought one. I always used a piece of brass brazing rod that I slit down the middle. The one I use now I found in a retired jeweler’s tool stash.
Jo
I would use a small O-Ring to keep it all from coming undone while in use.
