Regarding your post about cleaning gold, you mentioned using a
tinning block used for tinning soldering irons. Tinning block
seems to be sal ammoniac which is ammonium cloride, you said to use
ammonium sulphate.
Richard, you’ve not named the original poster nor used the original
message subject, so I cannot specifically reference an original
question. But that said, ammonium chloride (Sal ammoniac) has
traditionally been used as a “refining flux”, used to help remove
impurities when melting gold. Generally this refers to baser metals,
like lead, iron, tin, etc, which may contaminate the gold, or things
in your alloy from inadvertently included solder when reusing old
gold. It does not actually behave as one expects of a flux, ie
melting and covering/protecting the metal. Rather, a small pinch is
added after the metal has fully melted. It doesn’t melt, but instead
breaks down, releasing (I think) chlorine gas, or some compound
thereof. Lots of noxious blue smoke generated as the bits of
chemical skitter around on the surface of the molten metal,
evaporating away. Doesn’t take long and it’s gone. It works because
the chlorine aggressively bonds with the baser metals, selecting the
most reactive (baser) metals first, rather than the gold, silver,
copper, etc. These metals form chlorides which happen to be insoluble
in the metal, so the float to the top and slag off, mixed with the
remnants of your regular melting flux.
Don’t do this without really good ventilation. Those blue smoky fumes
are nasty. But it does work to improve previously cracky or brittle
gold. I’ve got references to this use of Sal ammoniac/ammonium
chloride in old books by George Gee in the late 1800s, where he
describes just this use and behavior (though at that time, melting
was done in a furnace, not with a torch as we might do today. He also
mentions plain old table salt (sodium chloride) as having a similar
use, though apparently it’s not as effective. I’ve not compared them
so I can’t say why that might be so, but that’s what Gee’s book says.
If you go to the German web site of jewelry tools supplier, Karl
Fischer, you can find another product used for a similar purpose.
They call it Auropurifax,
and describe it as potassium nitrate. A related product, Argoflux,
also contains this, plus other stuff, for use with carbon/graphite
crucibles. Not sure exactly the difference beyond that. Otto Frei
carries both of these (watch out for the hazardous shipping charges)
Presumably it does something similar, since this is a strong
oxidizing agent, which would also react first with baser metals,
again slagging off the oxides with your melting fluxes. I got a
bottle of this stuff years ago and have been using it up slowly
since. It seems to work about as well as ammonium chloride does, in
my experience which is only a casual comparison rather than any
really good side by side testing. It has the very big advantage of
not generating those noxious blue smoky fumes.
Hope that helps
Peter Rowe
