Hello all,
Unfortunatly due to lack of attention, I discovered recently that my
roller has a nasty layer of rust on the mills. We live by the sea,
so naturally the sea air has had a go at it. The last time I cleaned
it, I left a heavily oiled rag between the mills, under the
impression that it would stop the rust, on the contrary it trapped
the moisture and created my problem.
I have sanded it down manually, however there are small areas where
the rust has eaten into the mill by approx. 0.1mm, luckily I caught
it just in time before it got any worse. My question to you is, is
there anything else I can do myself to remove these pits, before
resorting to professional help? Any help and ideas would be greatly
appreciated, as we all well know that this is a very expensive piece
of equipment, and the worst of it is, that is is still brand new.
Many thanks, eagerly awaiting replys
Claire Drysdale
Cape Town, South Africa
