Does anyone know if it is possible (and practical) to change the rollers in
a rolling mill? My rolling mill has combination rollers for sheet and
wire. I need to roll sheet wider than the sheet portion of the rollers and
I don’t want to buy another rolling mill to do this. It doesn’t look easy
to change them but I don’t think that I would be doing it very often as
most of my work involves rolling sheet rather than wire.
Thanks,
Dennis
Note From Ganoksin Staff:
Looking for a rolling mill tool for your jewelry projects? We recommend:
Hi Dennis,
rollers in a rolling mill? My rolling mill has combination rollers for
sheet and wire.
It’s possible. How easy it is depends on what kind of mill & tools you
have. There’s an import mill (Karat) from India, that comes with 3 differnt
rolls, flat, wire & pattern. The same or a similar mill is also available
from Contenti (maybe others also). It sells for around $250.00.
Dave
My first rolling mill was one I bought used and came only with square wire
rollers. I brought the whole thing to a local machine shop and had a new
pair of flat rollers milled to fit. The original rollers were pressed
into the gear mechanism but Pete (machinist) removed them and refitted
them with a set screw so that now I can use each pair of rollers by simply
releasing them from the mill and removing/replacing the gears. Hope that
makes sense. Michelle
Sumiche Handwrought Jewelry
Creating what you want in gold, platinum and silver
http://www.efn.org/~sumiche
