Roll Printing
I know that a lot of us do roll printing. I have done some, but it is not a regular part of my operation. Since I am in the process of learning to engrave, I wondered if I could engrave a design in a piece of mild sheet steel and then use this to roll print the design on soft metal. Keep in mind that the engraving is a negative image and it will print a positive. I tried it with a small flower design and it worked very well, at least until I tried to polish with the same vigor that I always polish and the design disappeared in one spot. I did learn enough to know that it works. Just wondering if others also do this and what their experience is…Rob
Works great. I do that often. Usually carving a hard brass or mild steel printing “plate” negative with burs.
Andy…Attached should be a picture of the printed flower on the left and engraved plate on the right. The actual roll print is about .5" in diameter, so the picture is very close…Rob
https://photos.app.goo.gl/3FApMZvuQUTSqUM29
Hi Rob,
wow, that looks amazing!
julie
Progress Julie, I wouldn’t call it amazing. Take a look at Steve Lindsay’s website to see amazing. Thanks…Rob
Rob you can engrave and then use it for printing… you can also etch the steel as well as do photo etching if you want… I find photo etching lightly then touching up with the engraver saves my elbow a lot of stress…
enjoy.
Etching is on my list of things to try. Great idea to tune it up with engraving. Thanks…Rob
