Rofin laser and titanium welding
Howdy Folks,
I recently discovered that a Rofin laser welder is available for
rent in my area. I am an extreme newbie to metalsmithing but am now
very interested in titanium welding possibilities. What experience
has anyone had laser welding Ti? Do all welders have a cover gas?
Does Rofin? Can Ti be fused to sterling, gold or other metals? Can
the seam be etched and electrically colored? Any replies most
welcome. Carl 1 Lucky Texan
   What experience has anyone had laser welding Ti?
Some. You’ll need filler wire too, in order to get a fully filled
seam, on most types of work (just as with other metals). Reactive
metals Inc can sell you the wire, or, if you’re a masochist, you can
draw your own. But it’s really cheap to buy, and not so easy to
draw down to 30 guage…
All of the modern ones have the connections and nozzles needed. The
actual tank and regulator, etc, is usually an optional add on. It’s
not needed for all jewelery metals, but is useful for some,
especially white golds. So whether a given laser has it available
depends on whether it’s owner has bought a tank and regulator, and
keeps it filled. Argon isn’t cheap, and the laser can go through a
surprising amount of it if you use it regularely (or at too high a
pressure).
Yes. Gold works a bit better than silver. Silver takes a lot more
power to weld than does gold, so getting a clean weld can be tricky,
since at power levels needed to get the silver to melt, you’re
tending to blow holes in the Titanium. And the welds in silver can
tend to be brittle, which can be a problem if you can’t then anneal
the weld. But with some practice, you can do it. Using filler
wire made of silver solder, rather than sterling, helps a LOT.
This, by the way, isn’t unique to titanium. The same problems exist
in welding silver to other metals. high karat yellow golds too, also
can take fairly high power levels, and can be tricky to weld to
easier welding metals. Also, if the laser you’re using happens to
offer pulse shaping, you can avoid or lessen some of the problems
with weld cracking or brittle welds that some metals and combinations
thereof, can give you. The later models of the Rofin lasers (6000
series and later) offer this.
Can   the seam be etched and electrically colored?
Yes. As with any laser welds, the crystal structure of the weld is
going to be different than that of the parent metal, and if your
filler wire is a different alloy, that too might affect the anoziding
properites. So there might be some difference in appearance. But
often, you can get a seamless look, with a perfect match. note that
once you weld TI to someting else, anodizing gets a lot trickier,
since the something else tends to act as a current sink, preventing
anodizing, at least in the area of the other metal. So then you have
to get into masking the other metal. But it can be done.
Hope this helps.
Peter
Dear Carl
Welding Titanium does require a cover gas…preferably Argon. The
key to welding Titanium successfully is for the laser system to
create a “cloud” of gas in the welding zone so that there are not any
contaminants present. Some of the laser systems today that present
the inert gas into the welding chamber deliver the gas at a higher
rate than needed which in fact sucks oxeygen back into the welding
zone and creates problems with the Ti weld quality.
Be sure that the machine you are working in has a "flow regulator"
as opposed to a pressure regulator.
Crafford’s LaserStar Workstations provide a “soft flow” design when
the Argon is presented to the welding zone. We have many years of
experience welding Titanium since it is not only a popular alloy for
jewelry and eyeglass frame mfg. but also a principle alloy used in
the dental laboratory industry.
Feel free to contact the LaserStar Learning Center if you have any
further questions.
Also, if you would like to identify any LaserStar Workstations which
may be available to rent in the texas area, please advise. I know
there are more than 50+ units in the state.
Good Luck.
James Gervais
Crafford-LaserStar Technologies
Laser filler wire, .010in/.254mm, Grade #1 CP Titanium,
0.25lbs@$71.88. By the foot $0.065/ft. Bill
Help us conserve. See our online catalog @ <www.reactivemetals.com>.
If we can serve your needs we would be pleased to send you a free
catalog and put you on our 2002 mailing list. Please use the catalog
request form for a hard copy. Thank you. Deborah, Michele, Stephanie
& Bill
