Hey guys!
I were wondering since I always grind and clean up inside the ring-shank after I cast to make it smooth… Is there like an “average” of say xx.xx mm you grind of in the procedure?
An exmaple, if i want a ring to be 19.50 mm internal diameter… Should I then on purpose make and design the diameter a bit smaller, perhaps 19.10 mm, because 0.40 mm is grinded / buffed / polished away in the process.
Havent really had major fitting issues, but perhaps others have come across the same thoughts before?
Best regards
