Was: Ring sizes
Ring sizing is one of the most basic things I do. How do you do it? Let's say you are sizing a 14K yellow gold ring down from a size 6 to a 5.
Let's say that it has a single diamond, one-half carat round, as in an engagement ring. OK, I would cut one size out of the clean ring, pull the joint together, boric acid powder and alcohol all of ring, light it, flux joint and pull a small piece of 14K yellow hard solder through the joint with torch. Pulling the solder from inside the shank to the outside.
Clean ring, round it, file, and polish.
I suspect that there are a dozen or more ways to accomplish the same
thing…So, how do you do it
Thanks in advance.
Dale Pavatte
Diamonds For You, Decherd, Tennessee
