You have specified the user name “ito” as a recipient in an email
message (reproduced below), or the longer forms of Fuku.Ito
or F.Ito have been mapped onto the user name “ito”.
This user name is no longer valid as that person’s account has expired.
For further send email to Postmaster@mlb.dmt.csiro.au,
including the complete contents of this message.
Unsent message follows
Received: from proteus.imagiware.com (proteus.imagiware.com [206.215.211.3]) by asgard.mlb.dmt.csiro.au (8.7.5/8.7.1) with ESMTP id MAA27346 for ito@mlb.dmt.csiro.au; Tue, 12 Nov 1996 12:31:39 +1100 (EADT)
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id TAA26251 for orchid-outgoing; Mon, 11 Nov 1996 19:09:04 -0600
X-Authentication-Warning: proteus.imagiware.com: majordom set sender to owner-orchid using -f
Received: from asgard.mlb.dmt.csiro.au (asgard.mlb.dmt.csiro.au [130.116.3.1]) by proteus.imagiware.com (8.7.6/8.7.3) with ESMTP id TAA26232 for orchid@ganoksin.com; Mon, 11 Nov 1996 19:08:48 -0600
Received: (from daemon@localhost) by asgard.mlb.dmt.csiro.au (8.7.5/8.7.1) id LAA24212; Tue, 12 Nov 1996 11:08:56 +1100 (EADT)Date: Tue, 12 Nov 1996 11:08:56 +1100 (EADT)
Message-Id: 199611120008.LAA24212@asgard.mlb.dmt.csiro.au
To: orchid@ganoksin.com
Cc: @postmaster
Subject: Returned mail: message addressed to expired user name “ito”
Sender: owner-orchid@proteus.imagiware.com
Precedence: bulk
Reply-To: orchid@ganoksin.com
Received: from proteus.imagiware.com (proteus.imagiware.com [206.215.211.3]) by asgard.mlb.dmt.csiro.au (8.7.5/8.7.1) with ESMTP id LAA24203 for ito@mlb.dmt.csiro.au; Tue, 12 Nov 1996 11:08:52 +1100 (EADT)
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id RAA20858 for orchid-outgoing; Mon, 11 Nov 1996 17:51:50 -0600
Received: from asgard.mlb.dmt.csiro.au (asgard.mlb.dmt.csiro.au [130.116.3.1]) by proteus.imagiware.com (8.7.6/8.7.3) with ESMTP id RAA20834 for orchid@ganoksin.com; Mon, 11 Nov 1996 17:51:28 -0600
Received: (from daemon@localhost) by asgard.mlb.dmt.csiro.au (8.7.5/8.7.1) id JAA21556; Tue, 12 Nov 1996 09:51:37 +1100 (EADT)
Date: Tue, 12 Nov 1996 09:51:37 +1100 (EADT)
Message-Id: 199611112251.JAA21556@asgard.mlb.dmt.csiro.au
Cc: @postmaster
Precedence: bulk
Received: from shark.mel.dit.csiro.au (shark.mel.dit.CSIRO.AU [144.110.16.11]) by asgard.mlb.dmt.csiro.au (8.7.5/8.7.1) with SMTP id JAA21547 for ito@mlb.dmt.csiro.au; Tue, 12 Nov 1996 09:51:35 +1100 (EADT)
Received: from proteus.imagiware.com by shark.mel.dit.csiro.au with SMTP id AA03284
(5.65c/IDA-1.4.4/DIT-1.3 for ito@mlb.dmt.csiro.au); Tue, 12 Nov 1996 09:51:31 +1100
Received: (from majordom@localhost) by proteus.imagiware.com (8.7.6/8.7.3) id QAA15049 for orchid-outgoing; Mon, 11 Nov 1996 16:33:37 -0600
Received: from mercury.ConnectI.com (root@mercury.ConnectI.com [206.24.66.2]) by proteus.imagiware.com (8.7.6/8.7.3) with ESMTP id QAA15008 for orchid@ganoksin.com; Mon, 11 Nov 1996 16:33:18 -0600
Received: from default (ConnectI.253211 [207.51.253.211]) by ConnectI.com (8.7.5/8.7.3) with SMTP id PAA10342 for orchid@ganoksin.com; Mon, 11 Nov 1996 15:32:33 -0600 (CST)
Message-Id: 32879E05.38A9@connecti.com
Date: Mon, 11 Nov 1996 15:43:33 -0600
Organization: G.Chando Jewelry and Gems
X-Mailer: Mozilla 3.0Gold (Win95; I)
Mime-Version: 1.0
Subject: Re: (Fwd) little torch
References: UPMAIL02.199611111432220845@msn.com
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Precedence: bulk
Dave Sebaste wrote:
Oh… another thought on the pressure. I rarely go above 5 lbs to the torch.
Someone once told me that a good rule of thumb is to match the tip size with
the pressure. Therefore, if you’re using a size 3 tip, use 3 lbs. of
pressure.
Food for thought,
Dave Sebaste
An open fire or a charcoal fire is dangerous and heck even a home
fireplace can be the source of many types of danger.Just be careful and
use good hose the green and red rubber ones made for welding torches is
proper and don’t use the clear plastic since it melts and burns very
easily.Always shut the torch and tanks off when not in use.Extreme care
should be exercised with oxygen since in the presence of oil it is a
very powerful explosive so DO NOT OIL REGULATORS, TORCHES, FITTINGS,
ETC…I have seen an oxygen regulator that killed the operator when it
exploded from oil being in it and it blew the adjusting screw through
his heart.The oxygen is probably the more dangerous of the two tanks you
may need and the fuel is usually under much less pressure than the
oxygen.Put your tanks/cylinders at least twenty five feet from your main
work area.DON’T PLACE THE CYLINDERS UNDER YOUR BENCH. Fifty feet away
from your bench is not too far…hose or pipe or tubing is not that
expensive when you consider the cost of a wooden leg or worse yet the
cost of a funeral.I have seen it time and again, the shop with the tanks
stationed five feet from the torch and there is no excuse except
stupidity for having tanks in such close proximity to the open flame of
a torch.It makes me wonder if any of these guys have ever heard of or
read about the thing called a flash in the cylinder(flashback).You
probably have had a torch do it POP very loudly??? Well such an
explosion can happen inside of a fuel or oxygen cylinder quite
easily.The less distance from the torch to the tank the greater the
danger due to the fact that gas and oxygen only have to travel a short
distance obviously…Check valves according to my supplier actually
increase the danger
