Hello everyone. My name is Chad Dupuis and I am a goldsmith in
Baton Rouge, LA. I have just started to read this forum since I
recently found it. Great I have recently purchased a
laser welder. I read on a post somewhere that using "redi-tips"
works great. My question is: How do you hold the redi-tips prior to
tacking? Any “tips” appreciated. Thanks, looking forward to
participating in the future.
Weld on a small wire to give you a handle on the piece or use
tweezers.
Tim
A2Z Metalsmith Supply Inc
5151 S Federal Blvd Unit I-9
Littleton CO 80123
720 283-7200
Laser welder rental by the hour
www.A2ZMetalsmithSupply.com
Hi Chad,
Make sure you buy the solderless redi-prongs. I usually just use a
fine tip pair of tweezers to hold the caps. Sometimes I will take
Radico, which is a green compound used by watchmakers, on the end of
a 3mm wood dowel sharpened with a flat spot to hold them in place. I
also use Radico for covering heat sensitive and dark stones to avoid
damage from the laser beam.
Kevin
Hasko Jewelers
www.haskojewelers.com
