We made a vulcanised rubber mold of a ring with bead set diamonds
already in place. Does anybody have any suggestions for removing the
left over rubber from the underside of the diamonds? I have tried
soaking in acetone andthen burring underneath as much as possible,
but there is still some residue there. I am concerned about any
future torch work (tipping, sizing, etc) down the line.
Try lighter fluid. (Naptha) It’ll dissolve the brown gunk from
burning in the gates, and it’ll definitely cause the rubber to swell
if you leave it soaking too long, so clearly it does affect
vulcanized rubber.
Boil it out in lye. Get some drain cleaner, add it to some water.
Never ever add water to lye. Always add the lye to the water. Bad
things will happen if you don’t. Put the ring in, cover and bring to a
boil. Simmer on low till the rubber is dissolved. Sonic and steam. I
always do this before tipping diamonds. Have fun and make lots of
jewelry.
already in place.
We manufacture several kinds of rubber, including natural rubber,
RTV silicone and heat cure silicones. I am not aware of a good way to
remove any rubber you may have used, other than pick at. If somebody
has a cure for this, I’d like to hear it.
