I’m an amateur sculptor and I enjoy making silver jewelry. After casting, I want to smooth the surface of my sculptural pieces, but I’m not sure which tools or methods I should use.
How can I remove roughness and casting marks in very small and tight areas without damaging or softening the sculpted details?
I’m especially interested in techniques or tools suitable for micro details and complex surfaces.
Any advice, tool recommendations, or workflow suggestions would be greatly appreciated.
There was a fairly recent discussing on this topic, but it doesn’t quickly pop up in my search. If you find this discussion, it will include, but not be limited to, the following.
Filing using regular flat files and the various needle files.
Rubber abrasive wheels and points in different grits that are flex shaft mounted
Ceramic points in different grits that are flex shaft mounted
Using wooden sticks made from various straight grained wood that are charged with different loose silicon carbide or aluminum carbide grits. Think toothpicks
Emery or silicon carbide papers in various grits used whole or cut into thin strips to be pulled through small openings. Papers can be rolled on to different shaped objects to get into small places
Pieces of butcher string charged with different polishing compounds both stick or loose.
3M and others make many different open flap type abrasive wheels
Banana rolls
Moore’s discs
Discs cut from abrasive papers and mounted on a flex shaft mandrel.
Applying various grits and polishes directly to the surface with your finger. You might want to use a nitrile glove or put tape on your finger first
Research the processes by which steel dies are polished. Start with a review of the Gesswein website
Look at other websites and see what there is.
There isn’t a magic tool that will do this for you. You need to find what works for you.
If the details of your cast silver jewelry are important to you, it’s vital to get the as-cast surface as perfect as possible. Some jewelry is designed assuming that the entire surface will be ground away and polished, so positive casting defects aren’t a major problem. But if you’ve got fine details all over your pieces, grinding and chasing will never really bring them back; the best you can do is approximate them, with a whole lot of tedious labor. While some things, like sprue attachment points, are unavoidable areas that need cleaning up, you shouldn’t have to spend a lot of time elsewhere. If you post some pictures showing the castings in their raw state with the defects evident along with a description of your casting process, people here can probably share some tips about avoiding these issues in the first place.
The first step is to make the wax or plastic model as smooth as possible before investing and casting. Most post casting processes will remove metal and soften texture features. About the only way to preserve metal and remove roughness is to burnish the surfaces with highly polished hardened steel or tungsten carbide tools which will take a fair amount of time to accomplish and a skill that must be learned.
In addition to all of Rob’s suggestions, you can use old dulled burs (round, flame, krause, cylinder, bud, etc.) as burnishers in small tight areas. You can purposely dull them by running them against a dressing stone or sandpaper.
You can cut 3M plastic backed sandpaper into thin strips to mount in your saw frame.
Mounted, crimped steel wire wheel brushes can be used to brighten up cast details without removing material. If you use old ones that are worn down, the burnishing action will be firmer. Be sure to use a protective barrier because the flying pieces of steel wire are very nasty. I use the Matt polishing box to catch the steel debris and then pick them all up with a magnet.
You can remove the tip of an old bur. Heat the end red hot, give it a bend and hammer the bent tip a little flat. After it cools, finish the bent tip smooth and polish it with stainless or white diamond polish. This can be used with a flex shaft to burnish. You can try out different sized, angled, and shaped tips.
If you post photos of both waxes and castings, we’d all be able to offer a lot more advice! Different tools and techniques have different results. For example- there’s no point in sharing tips to get a perfectly smooth flat surface if all of your pieces have curves and textures.
How are you producing your castings? Lost wax, CAD or? In what material ? silver, brass?? or? What size are you working in - measurements and weight? For what market - asking because different markets require different levels of finish.. With a bit more detail, I can offer some solutions.
