Refining gold
Is there any easy way to take some 14kt gold and refine it to
22kt? Dave
Kickass Websites for the Corporate World http://www.kickassdesign.com
Crystalguy Jewelry http://www.opendoor.com/stephensdesign/crystalguy.html
Recumbent Cyclist’s Advocacy Group
http://www.opendoor.com/stephensdesign/bent/rcag.html
 22kt?  Dave
Add 24k.
22kt?  Dave
Sure.
Weigh the 14k, determine the weight of the components
(Au/Au/Cu), add the Ag and Cu weights together, work out what the
22k final wt would be for that amount of Ag/Cu, add 24k gold up
to that weight.
Melt and pour. What are you like at melting? I’ll assume you can
do that. Here’re my little quirky ways. I prefer to physically
clean the 14k (remove oxides, solder, etc) - not to pickle as it
can add sulphur to the melt. I’d also add a touch (less than 1%)
of copper-phos just prior to pouring to deoxidise what gets in
during the melt-up. Melt quickly, probably melt the 14k first
then add the 14k as the 24k has a higher liquidus. Pour into a
pre-heated steel and waxed mold - or into a diaper sling in a
bucket of water (Satsuo-Ando method).
Regards
Brian
B r i a n � A d a m J e w e l l e r y E y e w e a r �
@Brian_Adam1 ph/fx +64 9 817 6816 NEW ZEALAND
Brian Adam Eyewear artworks - spectacles
Brian Adam Jewellery earrings rings NZ jade
http://www.adam.co.nz/workshop/ NEXT: Queenstown NZ Jan 13 1998
http://www.adam.co.nz/ruthbaird/ Ruth makes her jewellery alongside me
