Materials: Sterling silver, wood, paint
Dimensions: 3" x 6" x 2"
Sterling silver die-formed and constructed.
Photo credit: Robly A. Glover
Nancy A Slagle
Lubbock, Texas. USA
This work is concerned with function as a means of creating modern ritual. The vessel is my means of expression. The vessel is a container of space and a definition of form. Planes and curves, static and kinetic, hard and soft, yin and yang, all these questions of balance are evident in the resolution of form. Through the manipulation of these elements movement, energy, and vitality have become apparent.
I have kept the scale conservative to promote an intimacy of relationship with the object. The approachability of the object supports the functional aspects of the work, making the use understandable and desirable. The scale and texture welcomes close inspection, which invites the viewer to pick it up and consider its use.
