I still have a programmable kiln available for sale.It is a
Neycraft and, basically is almost new (see specs below or contact
me off list). I know that Orchid prefers not to allow ads (a wise
choice), and that's essentially what this would be. I'll include
the specs here, but Orchid may edit them out, so contact me off
Linda
Programmable kiln manufactured by Neycraft. The model, as labelled
on the door, is “Vulcan 3-550 Ney”. The Operating Manual is included
with the kiln (includes instructions on programming the kiln). The
cover of the manual indicates that Neycraft describes this kiln as a
"Vulcan Box Furnace with programmable Controls". This kiln operates
on 120 volts.
Features of the kiln, as stated in the manual, are as follows:
High performance/Hybrid Muffle;
Operating temperature 50 degrees C (122 degrees F) to1100 degrees
C (2012 degrees F);
Vertical lift door, giving maximum access
programmable controller with nine (9) three stage programs (six
segments each) and 1 program with a single termparture hold;
heavy duty constructions with stainless steel front panel;
There are other miscellaneous features, but, in addition, this kiln
can be used for the following purposes: burn-out; metal clays; glass
fusing; ceramic firing; heat treating. This model kiln is currently
shown in the Rio Grande and other catalogues. It sells for around
$1395.00 plus shipping, but I am going to sell it for $900.00 as I
no longer will be using it.
I bought this kiln new from Rio Grande and haven’t used it for a
number of years, firing it a estimated maximum of 20 times. Although
this kiln shows no damage, either in the cabinet or in function, it
is being sold as a secondhand/used piece of equipment and therefore,
I am selling it “AS-IS”. The last time it was used, it functioned
perfectly. This is a solid piece of equipment useful for any of the
above-mentioned purposes and Neycraft has an excellent support and
tech staff able to handle any questions about the use of this kiln.
Price for the kiln: $900.00
